Mazda 6 engine rough idle.
Old Jul 12, 2025 | 10:37 PM
Nisdan's Avatar
Default Mazda 6 engine rough idle.
Hello,
My parents replaced there 2003 Mazda 6 for a new 2025 Mazda CX5. I have taken the old car and am trying to get ready to sell. I havnt worked on a car for a long time so thought it might be a good challenge and something to do. The issue is that it has a idle issue. I have been looking at alot of posts but most people's idle issues seem to be pretty drastic with 500-1000 rpm fluctuations. The issie i have is the car obviously has rough idle and when in reverse or drive it will lunge forward or back and not roll smoothly. I put my hand over exhaust pipe and could feel surges of exhaust coming out. Not sure what this means. Only other visible issue I can see is a slight wobble on pully idler. A mechanic was unable to fix this issue earlier in the year. He replaced MAF and EGR i believe. I have cleaned out the throttle body that was quite dirty.
I'll attach two videos.bits hard hear though and much more obvious in person. Any help would be great. I have heard tensioner for serpentine can start to fail. Any chance this could cause symptoms I have?
thanks,
File Type: mov
File Type: mov
Old Jul 15, 2025 | 02:36 PM
pishta's Avatar
sounds iike its hunting but the tach is stable? Check vacuum with a gauge for a steady 18+ inches and then IAC for a smooth motion. Its built into the electronic throttle, you can pop the side off and inspect the gears IIRC.
Old Jul 15, 2025 | 03:53 PM
Old Jul 15, 2025 | 03:56 PM
To many randomly guessed as the fault parts replace>>>>>>>>>>>>>>>>>
This makes it harder to diagnose because now a experienced person needs to back track and test all the replaced parts first.
Or if they are lucky find the issue or at least narrow it down a bit *by:
The first thing should have done a *complete comprehensive Diagnostic scan.
Masza
Nov 3, 2022 02:05 PM
devo76
May 30, 2022 06:41 PM
sslavik
Oct 11, 2017 09:34 AM
Audi
Jan 26, 2012 11:09 AM
