mass air flow problems Mazda 6 2.0 Diesel
Old Mar 22, 2019 | 01:17 PM
maz654's Avatar
Default mass air flow problems Mazda 6 2.0 Diesel
Looking for advice with a mass air flow sensor problem i have.
This started a few weeks ago the car would intermittently run rough loose power and smoke badly, i scaned for codes and got P0104 Mass Air Flow Sensor A Circuit Intermittent.
I have fitted a new sensor OEM quality but still have the same problem.
Any advice would be greatly appreciated.
2008 Mazda 6 ts2 2.0 ltr Diesel
Old Mar 24, 2019 | 01:03 AM
DTC P0104
Mass airflow (MAF) sensor circuit malfunction
DETECTION CONDITION
• The PCM monitors the input signal from MAF sensor. If the voltage of the MAF sensor is out of the threshold for 60 s or more, the PCM determines that there is a malfunction in MAF sensor.
POSSIBLE CAUSE
• Intake air system malfunction
• MAF sensor malfunction
• Connector or terminal malfunction
• PCM malfunction
Old Feb 6, 2021 | 02:30 AM
Fila's Avatar
Hi. I have the same problem. Can you give me advance. What to look for?
Old Mar 14, 2023 | 01:03 AM
torokoszkar's Avatar
I know its been some time since you posted this topic but I have the same issue with my Mazda for quite some time now and I could not find the cause. How did you fix yours?
I would greatly appreciate you response!
CharlieHorse
Feb 3, 2016 03:23 PM
pjhedtke
Nov 29, 2011 10:28 AM
MrSpike118
Sep 22, 2010 03:07 PM
PIMPINPHIL
Jun 14, 2010 10:45 PM
