GREDDY BOOST GAUGE QUESTION
Old Mar 10, 2008 | 03:56 PM
SickFrusciante's Avatar
Default GREDDY BOOST GAUGE QUESTION
I just bought the Greddy boost gauge and the directions are telling me to fit from the 3-way joint connector, the tube from the intake manifold, the fuel pressure regulator and then the last one to the boost sensor. I have the HKS SSQV blow-off valve and the tube from the intake manifold connects to the blow-off valve. My concern is, if I hook up the boost gauge the way the directions say, I'll have to disconnect the intake manifold tube form the blow-off valve and connect it to the 3-way joint which will leave an open connection on the blow-off valve. Is there a way around this or would it work if I just cut the intake manifold line and put a t-connector in it and run it to the boost sensor? I would appreciate any help, thanks guys.
Dale
2006 Mazdaspeed 6
mazda6diesel136
Mar 29, 2008 04:31 PM
SickFrusciante
Mar 10, 2008 06:40 PM
SickFrusciante
Mar 10, 2008 03:55 PM
liquidkace
Aug 9, 2005 05:55 PM
