Fog light wiring
Old Jul 6, 2005 | 04:10 PM
snesar's Avatar
Default Fog light wiring
Hi guys:
I have 2004 Mazda 6 sports package which has the fog lights integrated in the headlight. I want to install the bumper fog lights, the question I have is does anyone know if the wiring for bumper headlight is already there? I opened the underside cover and saw that there are floating connectors on both corners - just not sure if those are for fog lights. If they are, how do they turn on and off? using the same switch for the headlight fogs?
I'll appreciate the information if someone have tried to do this before OR if someone can look at the wiring diagram in the service manual.
Regards
snesar
Old Jul 6, 2005 | 10:02 PM
gtxtreme's Avatar
Default RE: Fog light wiring
Just paged thru the 04 wiring diagram manual, didn't show any extra wires. Your fog light run thru the main headlight connector,
12 wire connector, fog lights have a blue with white stripe (power from relay) and black with red stripe (ground).
You can check those two connectors with a test light, should only have two wires to them. If there are, one will only have power when
the fog lights are on, when check the other for ground.
Mazda lists a bumper mount fog light kit (#0000-8Z-H25A). Haven't installed any and we had didn't have a kit on hand.
Old Jul 7, 2005 | 03:30 PM
Fragile's Avatar
i believe that the mazda bumper fog light kit is not for the sports bumper...at leat not on the US Spec version.
ScottieB
Feb 20, 2013 09:49 AM
little_cee
Jan 26, 2008 06:47 PM
tigerpaw57
Aug 8, 2006 12:16 AM
mrtangM304
Sep 13, 2005 11:10 PM
khazoom
Sep 5, 2004 02:47 AM
