Cooling fan keeps running-motor hot
2006 Mazda 6, Sons girlfriend drove thru high water and broke off one of the fan blades on the cooling fan.
Took to repair shop, they said the radiator also had a leak. They replaced the cooling fan and radiator. They called and said the cooling fan is running too fast, another words it stays on all the time, also the engine is running too hot. I went by and spoke with them about it and they said could be the cooling fan module and they would continue checking the problem. Reading on the internet this has been an issue with Mazda. Would this make the car run too hot? They said the motor is getting up to 230 degrees. Thanks for any help |
3.0 V6 OR 4 banger?
Sounds like something clogged and poor circulation. Coolant Fluid should have been flushed and filled twice by now, more if changed over to cheaper green stuff. Earlier 3.0 V6 engines: coolant contamination caused by rust and corrosion in the coolant pipes that snake around the engine. This is often the result of coolant neglect. Cleaning and flushing the system can get rid of the gunk, but it won’t stop the corrosion inside the steel pipes. Replacing the pipes is recommended to halt the rusting problem. |
2006 should be the facelift & filled with long-life FL22 coolant which is good for 10 years or 200,000kms / 120,000 miles.
1 Attachment(s)
(Post 153414)
mazda 6 is not my area of expertise, BUT, sounds to me like air in the cooling system. needs to be properly bled. i went thru this a long time ago with one of our millenias. tried all the regular stuff, park on an incline, refill after each heat cycle, lisle funnel tool, none worked. finally, i got the uview vacuum fill system, and that is the ONLY way i fill cooling systems now. very popular in shops. fills the system 100%, dont have to refill after heat cycles, pulls open the thermostat so it fills everywhere. you need shop air for this tool. if a shop dont have a vacuum fill tool, i would go elsewhere.
Bottom-line pricing on UView 550000 at ToolTopia.com |
JR70895, where in the world are you?
Looks like different markets have either different coolant or different life spans.
1 Attachment(s)
(Post 153425)
My honest opinion of these maintenance items is that they are too late, and should be done sooner, perfect example on this sheet (that I was given when I purchased my Mazda 6 in 2006): transmission fluid and PCV valve. All manufacturesrs are pushing the limts so they can claim "low maintenance". According to this schedule, the automatic fluid should never be changed on a Mazda 6 Automatic transmission. That is the most ridiculous statement i've ever heard. You nead to read this article that discusses auto tranny fluid temps and longevity and they zero on 1 that says it's good for 100,000 miles: http://trucksplusauto.ca/transmission-fluid-flush-tips Here is a quote from that article: "As a rule of thumb, every 20 degree increase in operating temperature above 175 degrees F. cuts the life of the fluid in half! At 195 degrees F., for instance, fluid life is reduced to 50,000 miles. At 220 degrees, which is commonly encountered in many transmissions, the fluid is only good for about 25,000 miles. According to the Automatic Transmission Rebuilders Association, 90% of ALL transmission failures are caused by overheating. And most of these can be blamed on worn out fluid that should have been replaced. On most vehicles, the automatic transmission fluid is cooled by a small heat exchanger inside the bottom or end tank of the radiator. Hot ATF from the transmission circulates through a short loop of pipe and is thus "cooled." Cooling is a relative term here, however, because the radiator itself may be running at anywhere from 180 to 220 degrees F." If this is the case for an automatic tranny fluid that never needs scheduled replacing, according to Mazda, what is the reality for coolant! I am warning all car owners, get your maintenance done sooner as opposed to later. You know the old saying "Pay me now, or Pay me Later". Usually the later costs more money! https://www.mazdaforum.com/forum/mem...nance-3411.jpg |
2 Attachment(s)
PDF for Service schedule & PDF for FL22
(Post 153441)
Mazda is pushing buttons for low maintenance. I would never trust any coolant for that long because that's just ridiculous. :confused: It's too bad you are in Australia as not too many people from Australia actually asking for help on this forum. This also shows the importance of putting in your location in "User CP" under "Edit Details". It really makes it difficult to respond to questions on this forum, especially when most newbies don't post there location. |
