bose sub replacement
Old Jul 1, 2006 | 10:42 AM
Done3III's Avatar
Default bose sub replacement
I have the 2006 6i with the bose system. I'm thinking about replacing the stock sub with a powered unit and want to use the speaker level inputs from the original sub to send the signal to my amp. Anyone tried this yet and did it work ok or do I need some kind of adaptor, any info would be appreciated.
Old May 19, 2007 | 06:25 PM
atoznr's Avatar
Default RE: bose sub replacement
that's a great question. i don't have any info for you, but did you find out anything?
Old May 20, 2007 | 09:39 AM
esloyer's Avatar
i havent looked at the amplifier that powers the sub. it is under the driver's seat and is very hard to get to without taking the seat out. most likely two of the wires that go to the amplifer are the line levels for the sub. you could just take these off and use them or if you want to use both the bose and your new powered sub you could tap into the wire. though im not really sure which wire is what. maybe try searching google for a manual or tech service bulleitin on the bose systems... thats where i would start. let us know if you find anything
Old May 24, 2007 | 02:13 PM
t0md0's Avatar
i'll have to admit, having my audio system changed was one of the best things/investments i've ever done. sure i would like to go fast and look nice but i would also not like to spend thousands either. my thing has always been about the "sounds" in the car first, IF ANYTHING. i dont mind driving stock as long as my music sounds decent. actually, it'll probably keep the jackers from jackin my shiznit since my ride ain't all flossy (which i wouldnt mind if it was flossy btw).
any how, i didn't have the bose to begin with (which im glad since i have a better upgrade now anyway) so i'm not completley sure but i think either way you need a rca convertor to convertto the rightline level. if you are replacing the bose sub i would assume the boseamp as well. i guess it all depends if you are removing the whole thing, which i dont see why you wouldkeep both. i would guess taping into the original linethat goes into the bose amp. then after that, it's just plug and play. run new rca cables from the convertor to the new amp. keep in mind i'm pretty sure you'll still have to run power wires to the amp too.so that means running it from the battery. i don't know how else you can power the new amp... just my $.02 cents.
my current set up is nothing crazy but its simple and sounds decent. i'm not into major thumpingor ear piercing mid and high's but it gets me by:
metra turbo 2 dash kit <------$180 the price is an outrage if you ask me. i paid only $80 as gift.
alpine cda-9851
fosgate power series 5 1/4 components with speaker convertors since my M6are 6x8's
fosgate punch amp P250.1
fosgate 8 gaugeamp wire kit
an older singleJL 10" W0 sub in a sealed enclosure.
i plan to get the audiosteering wheel control module which is $60but i can wait since i have a remote control from my alpine anyway. i dont necessarily needboth a remote and asteering remote. would be nice dont get me wrong, but not necessary.
did the whole installationg by myself. only ghetto part is how i ran the power wire which will eventually be fixed to look cleaner whenran through the grommet where it should've been to begin with. i ran in from the left side fender so it shows when opeing the driver side door but get tucked immediately on the sidepanel. i dont mind it much since it's my side and no one else can see it. the grommet is tough as crap to poke through and i dont have the tool. i will seriouslyjust pay someone to do it cause it is seriously the hardest thing and i spent an hour trying to poke through without cutting any wires. then i said screw it cause it's to risky. other than that, it's a clean install.
good luck
Old May 24, 2007 | 02:36 PM
t0md0's Avatar
oh i just read this thread afterwards. https://www.mazdaforum.com/m_44098/tm.htm
i guess stealth is saying there're preamp outputs in the bose system??? i dont know but maybe you can only add on amp and speakers to already exisitingbosesystem???
either way i think best thing to do is just get a aftermarket head unit, sub and amp. you wont be sorry you did. you'd be amazed on the sound quality alone fromjust ahead unit upgrade. believe me because i upgraded my stockspeakers first which sounded good but then changed the head unit in a month later with same fosgate power components andit soundedeven better.i guess you might get away with keeping the stock bose and still sound decent and save money insteadof upgradingto new components.
the way i see it is if you knew you wanted thumps and an upgraded system, why spend money on the bose? now you're in a pickle of what to do since you dont want to completely change the bose system. but still want to sound better than stock bose system...
Jrod2460
Jan 6, 2017 01:13 AM
zen4life
Aug 27, 2013 09:01 AM
Centram
Aug 6, 2013 11:02 AM
dajaga
Oct 16, 2010 01:03 AM
FreakinToddles
Mar 13, 2008 11:50 PM
