4cyl. Check Engine Light Codes......
Here's the CEL codes for the 2.3 mazda6. Both the 3.0 and the 2.3 mazda6es information for these codes have been found on the mazda tech. website and I do not claim these findings as my own. I am just letting you all see what these codes mean if you run into them at any time.
ยด: Applicable
ยพ: Not applicable
DTC No. Condition MIL DC Monitor item Memory function Page
P0011 CMP timing over-advanced ON 2 CCM ยด (See DTC P0011)
P0012 CMP timing over-retarded ON 2 CCM ยด (See DTC P0012)
P0031 Front HO2S heater circuit low input ON 2 O2 sensor heater ยด (See DTC P0031)
P0032 Front HO2S heater circuit high input ON 2 O2 sensor heater ยด (See DTC P0032)
P0037 Rear HO2S heater circuit low input ON 2 O2 sensor heater ยด (See DTC P0037)
P0038 Rear HO2S heater circuit high input ON 2 O2 sensor heater ยด (See DTC P0038)
P0101 MAF sensor inconsistent with TP sensor or engine speed ON 2 CCM ยด (See DTC P0101)
P0102 MAF circuit low input ON 1 CCM ยด (See DTC P0102)
P0103 MAF circuit high input ON 1 CCM ยด (See DTC P0103)
P0106 MAP sensor performance problem ON 2 CCM ยด (See DTC P0106)
P0107 MAP sensor circuit low input ON 1 CCM ยด (See DTC P0107)
P0108 MAP sensor circuit high input ON 1 CCM ยด (See DTC P0108)
P0111 IAT circuit performance problem ON 2 CCM ยด (See DTC P0111)
P0112 IAT circuit low input ON 1 CCM ยด (See DTC P0112)
P0113 IAT circuit high input ON 1 CCM ยด (See DTC P0113)
P0117 ECT circuit low input ON 1 CCM ยด (See DTC P0117)
P0118 ECT circuit high input ON 1 CCM ยด (See DTC P0118)
P0122 TP sensor No.1 circuit low input ON 1 CCM ยด (See DTC P0122)
P0123 TP sensor No.1 circuit high input ON 1 CCM ยด (See DTC P0123)
P0125 Excessive time to enter closed loop fuel control ON 2 CCM ยด (See DTC P0125)
P0126 Coolant thermostat stuck open ON 2 Thermostat ยด (See DTC P0126, P0128)
P0128 Coolant thermostat stuck open ON 2 Thermostat ยด (See DTC P0126, P0128)
P0131 Front HO2S (stuck low) ON 2 CCM ยด (See DTC P0131, P0132)
P0132 Front HO2S (stuck high) ON 2 CCM ยด (See DTC P0131, P0132)
P0133 Front HO2S circuit malfunction ON 2 O2 sensor ยด (See DTC P0133)
P0134 Front HO2S circuit no activity detected ON 2 CCM ยด (See DTC P0134)
P0137 Rear HO2S circuit low input ON 2 CCM ยด (See DTC P0137)
P0138 Rear HO2S circuit high input ON 2 CCM ยด (See DTC P0138)
P0140 Rear HO2S circuit no activity detected ON 2 CCM ยด (See DTC P0140)
P0171 Fuel trim system too lean ON 2 Fuel ยด (See DTC P0171)
P0172 Fuel trim system too rich ON 2 Fuel ยด (See DTC P0172)
P0222 TP sensor No.2 circuit low input ON 1 CCM ยด (See DTC P0222)
P0223 TP sensor No.2 circuit high input ON 1 CCM ยด (See DTC P0223)
P0300 Random misfire detected Flash / ON 1 or 2 Misfire ยด (See DTC P0300)
P0301 Cylinder No.1 misfire detected Flash / ON 1 or 2 Misfire ยด (See DTC P0301, P0302, P0303, P0304)
P0302 Cylinder No.2 misfire detected Flash / ON 1 or 2 Misfire ยด (See DTC P0301, P0302, P0303, P0304)
P0303 Cylinder No.3 misfire detected Flash / ON 1 or 2 Misfire ยด (See DTC P0301, P0302, P0303, P0304)
P0304 Cylinder No.4 misfire detected Flash / ON 1 or 2 Misfire ยด (See DTC P0301, P0302, P0303, P0304)
P0327 Knock sensor circuit low input ON 1 CCM ยด (See DTC P0327)
P0328 Knock sensor circuit high input ON 1 CCM ยด (See DTC P0328)
P0335 CKP sensor circuit malfunction ON 1 CCM ยด (See DTC P0335)
P0340 CMP sensor circuit malfunction ON 1 CCM ยด (See DTC P0340)
P0401 EGR flow insufficient detected ON 2 EGR ยด (See DTC P0401)
P0402 EGR flow excessive detected ON 2 EGR ยด (See DTC P0402)
P0403 EGR valve (stepper motor) circuit malfunction ON 2 CCM ยด (See DTC P0403)
P0420 Catalyst system efficiency below threshold ON 2 Catalyst ยด (See DTC P0420)
P0441 Evaporative emission control system incorrect purge flow ON 2 Evaporative ยด (See DTC P0441)
P0442 Evaporative emission control system leak detected (small leak) ON 2 Evaporative ยด(DTC P0442)
P0443 Evaporative emission system purge control valve circuit malfunction ON 2 CCM ยด(DTC P0443)
P0446 Change over valve (COV) (EVAP system leak pump) stuck close ON 2 Evaporative ยด(DTC P0446)
P0455 Evaporative emission system leak detected (gross leak) ON 2 Evaporative ยด(DTC P0455)
P0456 Evaporative emission system leak detected (very small leak) ON 2 Evaporative ยด(DTC P0456)
P0461 Fuel gauge sender unit circuit range/performance ON 2 CCM ยด (See DTC P0461)
P0462 Fuel gauge sender unit circuit low input ON 2 CCM ยด (See DTC P0462)
P0463 Fuel gauge sender unit circuit high input ON 2 CCM ยด (See DTC P0463)
P0480 Fan relay No.1 control circuit malfunction OFF 2 Other ยด (See DTC P0480)
P0481 Fan relay No.2 and No.3 control circuit malfunction OFF 2 Other ยด (See DTC P0481)
P0482 Fan relay No.4 control circuit malfunction OFF 2 Other ยด (See DTC P0482)
P0500 Vehicle speed sensor (VSS) circuit malfunction ON 2 CCM ยด (See DTC P0500)
P0505 Idle control system malfunction OFF - - - (See DTC P0505)
P0506 Idle control system RPM lower than expected ON 2 CCM ยด (See DTC P0506)
P0507 Idle control system RPM higher than expected ON 2 CCM ยด (See DTC P0507)
P0550 PSP switch circuit malfunction ON 2 CCM ยด (See DTC P0550)
P0564 Cruise control switch circuit malfunction OFF 1 Other ยด (See DTC P0564)
P0571 Brake switch circuit malfunction OFF 1 Other ยด (See DTC P0571)
P0601 Internal control module memory check sum error ON 1 CCM ยด (See DTC P0601)
P0602 PCM programming error ON 1 CCM ยด (See DTC P0602)
P0604 PCM RAM error ON 1 CCM ยด (See DTC P0604)
P0606 ECM/PCM processor ON 1 CCM ยด (See DTC P0606)
P0607 Control module performance ON 1 CCM ยด (See DTC P0607)
P0610 Control module vehicle options error ON 1 CCM ยด (See DTC P0610)
P0638 Throttle actuator control range/performance ON 1 CCM ยด (See DTC P0638)
P0661 Variable intake-air system control solenoid valve circuit low input OFF 2 Other ยด(DTC P0661)
P0662 Variable intake-air system control solenoid valve circuit high input OFF 2 Other ยด(DTC P0662)
P0703 Brake switch No.1 circuit malfunction ON 2 CCM ยด (See DTC P0703)
P0704 Clutch switch circuit malfunction ON 2 CCM ยด (See DTC P0704)
P0850 Neutral switch circuit malfunction ON 2 CCM ยด (See DTC P0850)
P1410 VAD control system circuit malfunction OFF 2 Other ยด (See DTC P1410)
P1562 PCM +BB voltage low ON 1 CCM ยด (See DTC P1562)
P2004 Variable tumble control system (VTCS) shutter valve stuck open ON 2 CCM ยด (See DTC P2004)
P2006 Variable tumble control system (VTCS) shutter valve stuck closed ON 2 CCM ยด (See DTC P2006)
P2009 Variable tumble control solenoid valve circuit low input ON 2 CCM ยด (See DTC P2009)
P2010 Variable tumble control solenoid valve circuit high input ON 2 CCM ยด (See DTC P2010)
P2088 CMP actuator circuit low ON 2 CCM ยด (See DTC P2088)
P2089 CMP actuator circuit high ON 2 CCM ยด (See DTC P2089)
P2100 Throttle actuator circuit open ON 1 CCM ยด (See DTC P2100)
P2101 Throttle actuator circuit range/performance ON 1 CCM ยด (See DTC P2101)
P2102 Throttle actuator circuit low input ON 1 CCM ยด (See DTC P2102)
P2103 Throttle actuator control motor circuit high input ON 1 CCM ยด (See DTC P2103)
P2107 Throttle actuator control module processor ON 1 CCM ยด (See DTC P2107)
P2108 Throttle actuator control module performance ON 1 or 2 CCM ยด (See DTC P2108)
P2119 Throttle actuator control throttle body range/performance ON 2 CCM ยด (See DTC P2119)
P2122 Accelerator pedal position (APP) sensor No.1 circuit low input ON 1 CCM ยด (See DTC P2122)
P2123 Accelerator pedal position (APP) sensor No.1 circuit high input ON 1 CCM ยด (See DTC P2123)
P2127 Accelerator pedal position (APP) sensor No.2 circuit low input ON 1 CCM ยด (See DTC P2127)
P2128 Accelerator ped
ยด: Applicable
ยพ: Not applicable
lacawi
Nov 20, 2007 08:32 PM
