2015 Mazda 6 Touring Accident
Old Mar 15, 2025 | 07:01 PM
Smith1874's Avatar
Default 2015 Mazda 6 Touring Accident
In the event that a Mazda six has an accident with front end damage with airbags going off what safety device interrupts the power to the fuel pump relay so the vehicle cannot start
Old Mar 16, 2025 | 01:09 PM
Dany8888's Avatar
Meta IA says:
In a Mazda6, the safety device that interrupts power to the fuel pump relay in the event of an accident with front-end damage and airbag deployment is the:
Crash Sensor/Impact Sensor
When the crash sensor detects a significant impact, it sends an electrical signal to the:
Airbag Control Module (ACM)
The ACM then sends a signal to the:
Fuel Pump Control Module (FPCM)
The FPCM interrupts power to the fuel pump relay, shutting off fuel supply to the engine. This safety feature helps prevent fuel leaks, fires, or other hazards in the event of an accident.
Additionally, the Mazda6's electrical system is designed to:
  • Interrupt power to the fuel pump relay
  • Shut off the engine
  • Disable the ignition system
These safety features work together to minimize the risk of injury or damage in the event of an accident.
Old Mar 17, 2025 | 07:16 AM
Smith1874's Avatar
Great description . Where are these items located and how to re set them or clear them ?
Old Mar 17, 2025 | 09:47 AM
If you are asking this question then......
You shouldn't because of many SAFTY reasons. Find a trusted service shop and have them do it.
We get customers every week that think they can so often DIY on anything to vehicles but there are just some systems you need to have training to do both properly and SAFLEY!
Old Mar 17, 2025 | 10:31 AM
Smith1874's Avatar
The purpose of a forum is for questions and answers. Not a response of “take it to a shop”, but thanks for the input.
Old Mar 17, 2025 | 11:43 AM
Ok so dude please don't decide what you personally think forums are for. YOU DO REALIZE THAT THIS IS ALTHOUG PUIBLICALLY AVALIBLE IT IS STILL PRIVATELY OWNED.
And I did answer your question or did you not read it clearly and understand what I wrote?
I get so many that botch up DIY service and are driving around until they either get into an accident and can damage other personal property, their vehicles or worse ot the vehcle just stops working (better for everyone) because of a failed correct way to do a service. The SAFETY SYSTEM on your Mazda should not be done except by a SHOP plain and simple. But I am sure you will learn the hard way.
BTW newbie check into member profile before assuming anything about them as a new member on a forum. The answers I give don't get much better anywhere. And there is a reason for that. I am sure whatever your education and experience is may be claiming that same if there were a forum in your line of chosen career
So to repeat the service you are asking should be done by a service shop that has trained experiences and hopeful certified Auto Technician and or certified Auto mechanic and SHOULD NOT BE SERVICE BY A DO-IT-YOURSELFER !
HOWEVER IF YOU ARE THAT HELL BENT OF FUC'iN UP YOUR MAZDA EVERYTHING YOU NEED TO AND SHOULD LOOK AT HOW SHOULD BE EREAD CAREFULLY AND USEING ALL THE CORRECT DIGNOSTUIC TOOLS AND OTHER NESSISARY EQUIPTMENT ON ALLDATA. IT WILL COST A VERY SMALL AMOUNT BUT THIS HAS BETTER INFORMATUIION THEN ANY FORUM CAN PRIVIDE FOR WHAT YOU ARE ASKING TO ATTEMPT TO DO.
ASE
Do It Yourself Automotive Repair Information | ALLDATA DIY
Car Repair Advice Forum= at your own risk - Mazda Forum - Mazda Enthusiast Forums
Automotive Forums
Another source of information many people use on the internet are automotive forums. There are hundreds of forums dedicated to specific vehicle makes and models as well as more general automotive forums. Forums contain a wealth of information, but also a lot of misinformation and conflicting information.
The typical forum user will post a question in hopes that other forum users will respond and offer an answer or advice on how to solve the problem. But with all forums, there is no guarantee that anyone will respond or that any responses they do receive will be accurate or helpful. It all depends on the other forum members and who posts a response. Many forum users are quite knowledgeable and can provide exactly the kind of answer you are looking for. Other forum users want to be helpful and may venture a guess or offer an opinion that may or may not be accurate or may be totally wrong. In other words, it may be hard to distinguish good advice from bad advice.
Most forums are moderated to delete spam, rants and off-topic posts and comments that don't belong on the forum. But in most instances, the accuracy of the posts and responses is left up to the forum users. There's no editing or vetting or review of the comments that are posted. Consequently, if inaccurate or incorrect responses are posted to a question, other more knowledgeable users may or may not challenge a post or offer additional information.
We've seen many forum responses degenerate into endless bickering between conflicting points of view. We've also seen a lot of posts that totally contradict one another. There's nothing wrong with a good debate provided the people involved know what they are talking about. But unless there is some resolution to the debate, or some serious fact checking involved, the person who posted the original question may be left confused and no closer to finding an answer than when they started.
foui
Mar 20, 2024 03:02 AM
ckesanapalli
Mar 30, 2021 02:42 PM
brandon593
Apr 19, 2015 02:27 PM
ikeym
Apr 5, 2015 10:53 AM
maxinc
Aug 25, 2014 09:17 AM
