2003 Mazda 6 Tranny Nightmare
Old Nov 3, 2018 | 06:39 PM
icekillah's Avatar
Default 2003 Mazda 6 Tranny Nightmare
I thought i would Clarify not Tranny as a cross-dresser Tranny as a Transmission. Short story is a mechanic installed a "new/working" Tranny into my 2003 Mazda 6. It does not drive right at all! Reverse works properly and shifts smoothly. Drive is a different story, From a cold start you need to keep it at 3k-4k rpms for 2 minutes before it will even start to go forward, after it starts moving it can be driven around with moderate confidence that it will not "slip". The mechanic had a hard time reinstalling the Shifter cable, but the proper gears light up on the dashboard when the gear shifter changes gears, so i dont think its a cable issue. I am getting A/T codes for "Incorrect gear ratio" on gears 1,2 and 3. The mechanic never mentioned anything about installing a new TCM or Transmission computer. Is it possible he installed a different style of transmission that my stock TCM cant control? Any thoughts or insights will help greatly. Has anyone done a Tranny swap and knows the procedure, or what components need to be adjusted/swapped for this job to be successful?
Old Dec 10, 2018 | 03:50 AM
6 gang's Avatar
the tcm has to be reflashed or the transimission is no good
Andreas92
Jun 14, 2019 10:56 AM
kizzoboy
Mar 30, 2016 10:47 AM
mayberry56
Aug 19, 2009 07:33 AM
wesley83
Aug 18, 2009 12:15 PM
calvin
Oct 4, 2004 10:37 AM
