03 mazda 6 ignition problem
Old Dec 23, 2010 | 02:39 PM
adam-50's Avatar
Default 03 mazda 6 ignition problem
someone tell me if i am on the correct path. The car tries to start but when you release the key it dies. I hooked it to my code scanner to check for stored codes and there were none. so i tried to run a koeo check and the scanner says the ignition switch is in the off position when it is clearly in the on position. does this tell me that the whole issue is with the ignition switch itself? thanks.
Old Dec 29, 2010 | 03:00 PM
Nigel 206's Avatar
Hi there.
Sounds like a key problem. It contains a chip which is 'read' by the ign switch.
It may have been corrupted in some way.
Have you tried one of the spare keys?
boomshiko
Dec 19, 2010 04:01 PM
rainman2736
May 11, 2007 10:30 AM
Yung_Pinoy
Nov 19, 2006 01:13 PM
eugene87
Sep 20, 2006 10:26 PM
3kgtman
Mar 22, 2006 09:59 PM
