03 mazda 6 high pitch squealing when accelorate, brake, turn
Old Nov 22, 2007 | 11:54 PM
ktadele's Avatar
Default 03 mazda 6 high pitch squealing when accelorate, brake, turn
Had my 03 Mazda 6 towed to the dealer because of a loud high pitched squealing noise that started while turning on a freeway entrance ramp. Continued while accelorating/coasting, braking and turning, but stopped when idling. Car has 47k miles (I purchased it 6 months ago), had brakes checked two months ago and I was told I shouldn't need the pads replaced until I reach approx 70k. Also had engine light diagnostic and oil change two weeks ago. Dealer did not mark anything on brake inspection- no indication on wear, or even if they checked the brake pads at all... any ideas about what the sound could be? Thanks
Old Nov 23, 2007 | 07:56 PM
davidteachey's Avatar
Default RE: 03 mazda 6 high pitch squealing when accelorate, brake, turn
Note: my front pads lasted exactly 40k miles, then the wear indicators started screeching. This might be your problem.
Assumption #2 is that you have a loose belt, which is fine at idle, but once it's loaded, it screeches.
Please write back and let us know what theproblem proved to be, ok? Good luck,
David
ktadele
Nov 22, 2007 11:52 PM
Runner54
Sep 18, 2007 02:23 PM
Adzam Etubirt
Feb 7, 2007 05:19 PM
99mazda1.6l
Nov 29, 2006 10:58 PM
Sassy07
Oct 19, 2006 04:30 PM
