-   Mazda5 (https://www.mazdaforum.com/forum/mazda5-43/)
-   -   Radiator replacement (https://www.mazdaforum.com/forum/mazda5-43/radiator-replacement-28363/)
Klewless Jan 15, 2012 07:56 PM
Hi everyone, new member here with a radiator problem. My 06 Mazda 5 has developed a coolant leak on the passenger side plastic radiator tank. I understand that I will have to replace the radiator and I was wondering if anyone on the forum has replaced their radiator and could share their expertise on the process. It's been a while since I've turned wrenches and I just wanted to make sure that this is a project that I can handle. Any input would be greatly appreciated!
tanprotege Jan 16, 2012 10:56 AM
Once in my time I replaced a radiator and broke it! The material was so thin, I couldn't get the bottom hose on. Meanwhile I learned that a little bit of lubricant helps.
I suggest you look at some Youtubes on replacing the radiator.
I would rather pay a pro so I have someone other than me to blame if it goes wrong.
BCNorth Jan 16, 2012 12:02 PM
So the plastic tank had a leak and that results in replacing the entire radiator? Did I miss something? Why cant the tank itself just be replaced?
Klewless Jan 17, 2012 06:55 AM
From what I've been told the radiator is a throw away "non serviceable" part and when a leak develops in the plastic tank the only remedy is replacement of the entire unit. I have read online by several posters that glueing the broken tank is a temporary fix at best and you will ultimately have to replace the radiator anyway. I referenced the Mazda repair manual and it says I will need to remove the entire front bumper and grille assembly to access the radiator for removal! Boy this sounds like fun.
