Mazda 5 power sliding doors
Old Today | 10:15 AM
Darthun's Avatar
Smile Mazda 5 power sliding doors
Hello.
I've got a problem with power sliding door on the right hand side of the car. It starts to open normally and then stops right before fuel flap. After it stops moving i cant close it even if i turn off the power sliding doors. Any ideas what could be causing the issue?
Old Today | 10:33 AM
Old Today | 10:36 AM
Mada info :
Year
septic trim
miles on odometer
when was the battery last tested by way of load test
What was the last service done and what was it?
Old Today | 10:51 AM
Darthun's Avatar
195110 miles on the clock
battery is 3 days old
i dont know about any service because i recently got the car
Old Today | 11:13 AM
Originally Posted by Darthun
2009
At those miles there are several things to check with your door operation. The first is the door alignment.
Then make sure that the door jam and all areas are completely cleaned. Soap water and a sponge. If needed reapply white lithium grease to some operation area's sparingly after cleaning.
The battery should be load tested. If it was not load tested before installing it even if you purchased it new, then your battery may be part of the problem? New does not mean good.
Lone_slayer
Aug 21, 2018 11:14 PM
Ericson A
Oct 2, 2014 06:08 AM
LUVmyMPV
May 15, 2008 10:04 AM
LUVmyMPV
May 15, 2008 09:56 AM
