mazda 5 engine compatilbe with mazda 3 engine
Old Mar 10, 2011 | 05:58 PM
ggarcia77's Avatar
Default mazda 5 engine compatilbe with mazda 3 engine
does anyone know if the mazda 5 engine and mazda 3 engine are compatilbe i have a mazda 5 2007 gonna get a mazda 3 engine 2006
Old Mar 11, 2011 | 07:57 AM
lnwlf's Avatar
If you are referring to the 2.3 liter engine, they are identical as well as transmission and suspension. the spring rates are different between the two to accommodate the weight difference. I can only speculate that the ECU will plug right in as after market ECU's for the M3 are compatible with the M5.
Old Mar 12, 2011 | 01:31 PM
ggarcia77's Avatar
ok well wht if the motor is a 2.0 my engine in my mazda is a 2.3 liter ?? its an 06 mazda 3 and mine is a 07 mazda 5
Old Mar 12, 2011 | 02:33 PM
lnwlf's Avatar
here in the U.S. the Mazda 5 has the 2.3, in the U.K. and Japan there are different engine options. I'm not sure if the model year will make a difference, as long as it's the 2.3 it should be compatible. why do you want to swap?
Old Mar 23, 2011 | 07:36 PM
ggarcia77's Avatar
my engine is blown and i need a new crank and bearings do you know anywhere that sells engines or cranks and so forth! i need a new engine and so forth! DO you know anyone thats sells ? you seem to be the most informative about the engine please let me know!
Old Mar 24, 2011 | 02:55 PM
lnwlf's Avatar
well I wouldn't go as far as saying I'm the most informative about the engine, but, I believe this website may have what your looking for, if not give them a call and maybe they can help you further.
Mazda Parts Center - Call (800) 650-4896 for up to 30% Off on Genuine Mazda Parts and Accessories
