RyanL |
03-29-2016 05:37 PM |
Any way to clear the ABS light?
Hello all. Trying to figure out if there is a way to manually clear the ABS light on a Mazda5 just like you can with a Protégé (aside from going to the stealership). I believe some high end code scanners have this capability, but the mini bluetooth one I have doesn't read/clear ABS codes (some cheapo elm327 or something) nor did the one at Advanced Auto. Oh BTW, the reason the light is on is because I just changed one of the front CV joint boots last night (project ran into the night) and I missed the speed sensor wire. Connected now, but obviously it set off the ABS trouble light and driving it around doesn't clear the issue. Thanks for any tips.
