AC System issues
Old Jul 8, 2024 | 10:42 PM
Masonc's Avatar
Default AC System issues
Hello, I recently purchased a 2012 Mazda 5 Sport with 146k miles, runs great, having issues with the AC lately, when the temp outside reached 100 degrees F the AC system starts cycling on and off over and over, I've vacuumed the system and refilled it properly, still Didn't fix it, I noticed when refilling some bubbling around the Schrader valve on the low side so I replaced it and refilled again, Still the problems persists, I checked coolant levels and they're perfect, any thoughts? I'm starting to lean into the system just being worn and tired, just wanted a second opinion on it before i dig deeper into this. note it'll run fine till the temp outside hits about 100F ambient then it cycles, and yes when recharging I followed the ambient temp chart for PSI and at 100 degrees is about 54PSI and at lower temps its where is should be aswell.
Syrus
May 12, 2022 09:45 PM
rujoesmith
Sep 15, 2021 06:48 AM
emolvera
Jun 30, 2020 11:11 AM
mommyhead
Aug 19, 2019 07:16 PM
Simon Gilmour
Jun 18, 2018 02:40 AM
