2009 Mazda 5 stalling and idling rough after battery replacement
Old Jan 21, 2024 | 08:27 PM
Jillsboys's Avatar
Default 2009 Mazda 5 stalling and idling rough after battery replacement
Today I had the battery replaced on my 2009 Mazda 5. On the way home from the auto parts store where they installed it after purchase, my car stalled out when going through a roundabout and is idling rough as well. Do I need to reset the computer? If so how do it?
Old Jan 21, 2024 | 10:28 PM
Disconnect battery, clean throttle body, reconnect battery, start engine with no loads, allow to idle for a few minutes then drive normally.
Old Jan 22, 2024 | 03:08 PM
Grim..... with that year can't he do hard reset of the drive-by-wire?
Turn ignition to start position, floor the throttle for about 5 seconds, release and the start engine normally?
However should the throttle body be cleaned make sure to use only throttle body cleaner so as not to damage the electronics'.
Old Jan 22, 2024 | 08:11 PM
As the throttle body slowly clogs up over time the PCM learns the small changes in the TPS, when the battery is disconnected the PCM looses this learnt data, when the car is restarted the PCM has no idea on throttle condition.
Cleaning the throttle is the only option.
rnewton80
Sep 7, 2023 09:32 PM
Omer Asher
Feb 15, 2020 09:22 AM
Ach3r0n
Jul 8, 2009 10:15 PM
Bob Hubbard
Dec 1, 2008 11:40 PM
