1999 Mazda 5/Premacy Speedometer stopped, ABS Light,Brake Light on
Hi,
I'm new to this forum and I have several lights on my dashboard: ABS Light, Brake light plus my speedometer doesn't work I'm also confused about the model Mazda I bought. It is called a Mazda5 in the US and is listed as a Premacy here in New Zealand. The plate under the hood shows body code: UA-CPW8. No where it shows that it is an AWD but it definitely is, (Long shaft going to diff at rear :) ) Re - Speedometer I'm struggling finding a Speedometer sensor, maybe there is none? Could it be a fuse? Re- ABS and Brake light I had the rear brakes serviced (disc pads, not the drum brakes) They had to rebuild a stuck caliper because they couldn't find a replacement caliper in the whole of New Zealand!? after this the ABS started to come off and on. When I called them to explain they said it is non related, it may be a sensor? Anyhow, thanks for anyone who is willing to shed some light on these issues? :confused:https://cimg1.ibsrv.net/gimg/www.maz...f87683ff1c.jpg https://cimg3.ibsrv.net/gimg/www.maz...4020e0fa24.jpg https://cimg4.ibsrv.net/gimg/www.maz...68d3eee74d.jpg ANDRE |
On some cars the speed is read from an ABS sensor. It could be a loose plug, broken wire or bad sensor.
