What's the best OBD2 scanner for Mazda?
Old Sep 29, 2016 | 01:36 PM
mazdacx's Avatar
Arrow What's the best OBD2 scanner for Mazda?
I have recently purchased a Mazda 3 and would like to know what is the best affordable OBD2 scanner for these cars.
From my research I can see that the dealer uses the IDS software but that doesn't make sense for owners like me. What I am trying to find is a scanner that will be able to read and clear codes from:
-ABS
-SRS
-Engine
-Transmission
Those are the main systems that I am concerned about. I know that generic OBD-2 code readers won't work.
What are your recommendations?
Old Sep 29, 2016 | 01:51 PM
mazdacx's Avatar
In case you were wondering this is a 2014 Mazda.
Old Sep 30, 2016 | 10:09 PM
mazdacx's Avatar
Bump^ No one has any recommendations? Which OBD II scanner have you used? Were you able to clear ABS SRS codes?
Old Oct 1, 2016 | 06:11 AM
Snap-on
Old Oct 2, 2016 | 01:51 AM
JeffMD's Avatar
what are abs and srs codes and how are they different from normal codes? -_- If you are looking for statistics, it needs specialized software so pony the big bucks. If you wants fault (CEL) codes, it should go in the same bin as the rest.
Old Oct 2, 2016 | 05:13 AM
ABS ( Brakes & stability controls) and SRS ( Airbags) are both separate modules, most budget code readers will only read PCM/ECU codes.
Old Oct 15, 2016 | 07:30 PM
mazdacx's Avatar
UPDATE!
First, thank you all for your replies. I have spent countless hours researching a good OBD2 scanner for Mazda that will be able to read and clear codes from transmission, ecu, abs and srs. Yet still need to be within my budget.
There are a couple of options out there that can do this. There is a great article that talks about several Mazda scanners that are able to do in depth troubleshooting. Do a quick search for: Best OBD2 Diagnostic Scanner for Mazda | YOUCANIC
Old Oct 15, 2016 | 08:34 PM
JeffMD's Avatar
I was able to net a bluetooth scanner that works reasonably well at BAFX Products BAFX3127 Bluetooth OBD2 Diagnostic Scan Tool for Android Only-Newegg.com
Its a $23 clone but well reviewed and I had no problems getting it to work with torque on my 2016 mazda3.
Old Oct 16, 2016 | 02:00 PM
mazdacx's Avatar
I have used that same Bluetooth adapter too. That's not able to diagnose anything else than the engine. I was in hunt for a scanner that could diagnose SRS, ABS and transmission problems as well.
Old Oct 17, 2016 | 02:26 AM
JeffMD's Avatar
Ah yes, you know I scanned this thread and didnt see my previous post. ^^ Yea srs/abs is specialised. Don't know the logic behind common readers not accessing it but... until they do, big bucks you will spend.
