VVT actuator Pin damage?
1 Attachment(s)
I figured based on other pics I've seen that this isn't a healthy VVT? (pic attached)
Just wanted to check with others before buying an aftermarket replacement. |
Doesn't look good to me, I'd replace it. That timing chain is one stout little bugger, eh?
-CD- |
Very Stout!
I replaced it, but I am now wondering if the VVT camshaft is supposed to have a little play in it? It's not much, I would say 1mm on the outer circumference at the alignment end of the camshaft, or according to SOH-CAH-TOA, that works out to approximately 0.1 degrees of play. I am guessing its because of the VVT actuator? |
