Turn Signal Flasher Location
Wow Richard that's the first I've heard of anyone needing a resistor wired to their brake light. Honestly I don't see why you would need one to keep the cruise control working as AFAIK it should continue to work even if the brake lights go out (i.e. vastly decreased resistance).
ORIGINAL: icspots
ORIGINAL: Siber Express
I think because the less voltage and/or wattage to light up the LED's a bump that bounces the brake petal a little bit that would not light up the normal bulbs will light the LED's completing the brake circuit, I have a load resister in my LED lights on my work truck (mounted on the Cab Shield) for the same reason, the cruise would kick off.
ORIGINAL: icspots
I plan for now to keep the side markers as TF bulbs, so would I need to put a resistor in each one of those as well to keep the rapid flash away? I'm hoping not, since I only ordered 4 of the resistors. This is what I bought: http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
Will those be good enough? They are 50 watt 6 ohm resistors.
ORIGINAL: 04Mazda3Sport
ORIGINAL: icspots
Wow Richard that"s the first I"ve heard of anyone needing a resistor wired to their brake light. Honestly I don"t see why you would need one to keep the cruise control working as AFAIK it should continue to work even if the brake lights go out (i.e. vastly decreased resistance).
Plenty, though their prices are not the best I"ve seen. 50 watt is overkill, but will work fine.
You don't have to get the ballasts that these people sell. You can do it much, much cheaper by going to an electronics store and getting a regular ceramic resister. You have to come up w/a way to mount it and you would have to solder the leads.I"ll save the $7-$10/ea and buy the same thing for $1 and do my own work to them.
edit: MAANNNN!!! I just looked again at some of their prices and they are HIGH!!!! $40 forONE bulb!!!
Try this site next time: http://autolumination.com/
I would use The Xenon store http://www.thexenonstore.com/ledbulbs.php Their prices are cheaper and he has a few other Mazda 3 goodies.
