Transmission Fluid Capacity
Old Jan 20, 2015 | 12:56 PM
KAC's Avatar
KAC
Default Transmission Fluid Capacity
Greetings All...I'm having an issue determining the appropriate amount of automatic trans fluid. The ride is a 2008 Mazda3i 2.0 automatic 4 speed. All owners manuals and online references indicate around 7qts. Most do DIY forums indicate 3-3.5qts. I recently did a flush (3 in - 3 out) and afterwards put 3.5qts in and at normal operating temps my level appears over the dip stick full line.
Any advice?
Old Jan 20, 2015 | 04:49 PM
hixx's Avatar
You will see 2 different fluid capacity numbers because one is total capacity and the other is drain and refill. Total capacity is used after an overhaul. When servicing the trans add 1 quart or so under the service fill capacity, start the engine and put it in forward and reverse a few times then put it in park and let the engine warm up until the cooling fans kick in. Check your fluid level with it in park and running.
Old Jan 20, 2015 | 07:39 PM
KAC's Avatar
KAC
There it is...makes perfect sense. Thank you!
mmiller2002
Feb 15, 2007 12:07 AM
easye1097
Aug 10, 2006 06:23 PM
easye1097
Aug 10, 2006 06:22 PM
shecky
May 4, 2006 10:22 PM
aircooled
Oct 31, 2005 06:01 PM
