Rough engine on cold startup
Old Aug 6, 2007 | 02:09 PM
LordChrisofSith's Avatar
Default Rough engine on cold startup
2007 3 I. 2.0 auto. Sunroof. 16 inch wheels.
It may just be me. But has anyone notice the engine being shakey on an overnight/morning startup. Goes away after 30 seconds. (Which I assume is oil moving around) Just kind of weird. I wonder if it has a loose bolt in the mount. But, then it should shake all of the time. No worries till it falls out I guess. Quiet and smooth otherwise.
Old Aug 6, 2007 | 05:21 PM
Default RE: Rough engine on cold startup
To me, these engines are not the most civilized around. Yes, I have noticed a bit of unrest on cold start-ups. Not an unusual situation, imo.
You should try a harder rear engine mount w/the A/C on. Then you'll experience shaking.
Old Aug 6, 2007 | 05:45 PM
MazdaN00b's Avatar
ORIGINAL: virgin1
yeah, he aint kidding. by my car runs rough all the time though. I always get nervous. even before the 3rd mount.
Old Aug 6, 2007 | 11:52 PM
UrbanmanUSA's Avatar
ORIGINAL: LordChrisofSith
I have the 2007 3i w/auto, and I have never noticed this. Minehas always been exceptionally smooth. BeforeI turn the motor off, I shut off all lights, completely shut down the climate control, and let the engine idle for about 10 seconds-might that make a difference? Ivery oftendon't drive my car for 2-3 days(I'm a mass transit user), and its still very smooth on start up.
Old Aug 7, 2007 | 07:17 AM
You mean you guys had the car in to have the rear eng mount replaced. Or, is this an aftermarket thing you have done....
As far as knowing how to shut a car down. Of course I shut everything off and let the car idle for a bit to cool things off. Mass transit user. Where do you live New York?
Old Aug 7, 2007 | 06:27 PM
http://www.awrracing.com/mazda3/index.html
Often known as the torque mount. It helps reduce wheel hop on take-off and puts the power down better in general. But like most changes there is a trade-off.The 70 is kinda' rough. I can only imaginwe what the 88 is like.
ORIGINAL: LordChrisofSithAs far as knowing how to shut a car down. Of course I shut everything off and let the car idle for a bit to cool things off. Mass transit user. Where do you live New York?
I do most of that too, except I'm not carful @ all about shutting the heating/climate system down.Makes no difference in mine.
Old Aug 7, 2007 | 10:38 PM
ORIGINAL: virgin1
V1, when you say the above, are you referring simply to the fact that they can be a bit noisy/shaky for some drivers... or something different?
Old Aug 8, 2007 | 01:45 PM
No. That's it.
There are many "tamer" 4-cyl in line engines out there, but I wouldn't trade mine for the world.I do feel like it could be better balanced though... or perhaps it's tuning? I'm not sure. 'Course when you start getting above 2.0L, it's hard to balance a traditionalin line four. They start getting shaky. Hence the use of (counter-)balance shafts.
Old Aug 10, 2007 | 10:07 AM
npoll212's Avatar
just let the car idle when u start it up until the rpms drop to about 1k then it should run smooth, i have the 2.3l and i do this every time i start it up
Old Aug 13, 2007 | 09:41 AM
Yep. I noticed that when I first start it in the morning. The RPM's are at 1500 for a few seconds. Then it comes down and smooths out.
jordoe28
Apr 4, 2015 08:45 PM
Bender
Oct 9, 2008 09:48 AM
Frankd1
Nov 14, 2007 03:12 PM
RX786
Oct 25, 2006 02:00 AM
neeltampa
Oct 3, 2005 09:25 PM
