replaced headlight bulgs, now lights dont work
Old May 19, 2011 | 09:45 PM
smooooooke's Avatar
Default replaced headlight bulgs, now lights dont work
Hope i'm posting in the right area. I made a rookie mistake and disconnected the battery when replacing my headlights (was being over-cautious). All lights work except for my headlights. Checked fuses, seemed fine. Everything is plugged in. Do I need something reset from mazda? If so, anyway I can do that without going to the dealer? Any help is appreciated.
Old May 20, 2011 | 12:04 AM
cornwellbs's Avatar
thats not a mistake, you should always disconnect the battery when doing any electical work
Old May 20, 2011 | 12:11 AM
smooooooke's Avatar
I think the mistake was that I took off the positive first before the negative. Turns out that was a very bad idea as I finally came across a link that had some information regarding it:
how long to reset ECU - Mazda3Club.com
Maybe I should try disconnecting the negative, then positive... hitting the brake to drain everything, then put on positive, then negative and hope for success? Or would that be a bad idea?
here is a little more info. My highbeams, signals, fog lights all work fine...just the normal headlights that don't. no fuses seem to be busted unless I checked the wrong ones (I did not check all of them...I went off the chart in the manual...i checked the 40a fuses). All other electrical seems to work 'cept for the headlights. My only concern with taking all power away is losing more than just my headlights.
Update: I ended up unplugging the battery completely (properly this time) and hit the brakes a few times. Started it back up and still no headlights. Everything else seems to work still. If no one has any ideas, I'll just be taking this into a mazda dealership and make them find the problem so I can fix it myself.
Old May 20, 2011 | 10:39 AM
cornwellbs's Avatar
ahhhh yeah thats not good lol nagative always first lol as far as how to reset it im not sure
Old May 20, 2011 | 03:32 PM
smooooooke's Avatar
Well, took it to a normal shop and they checked the fuses and said they were all fine. They suggested going to an electrical shop which I'm going to do. Too bad I didn't know more about electric in cars...I bet its not even that hard either.
Unless anyone else has any other suggestions, I'll be paying someone to fix it tomorrow morning.
Old May 20, 2011 | 06:22 PM
icspots's Avatar
Did you check all of the fuses/relays in both the engine bay fuse box and the one behind the glove compt?
The next thing I would check is that your connections as the lights are solid. Then I would pull out a multimeter and see if you actually have power to the harness.
If you have the OEM halogens did you pull the H7 adapter off the back of the old lamps? If you have the OEM HIDs it could be the ballast that's bad.
Old May 21, 2011 | 02:30 PM
TA2DMAC's Avatar
When changing the bulb did you touch the bulb lens at all? Halogen lenses will blow form the oil in your skin. I purchased Sylvania exta brights and they didnt work. Went to the regular sylvania whites and they worked fine. I've purchased lights many times where one was defective. Also when you remove the adapter check all the posts to make sure they are clean and add some diaectric grease to keep water out and a good contact.
Old Sep 10, 2012 | 02:43 PM
smooooooke's Avatar
Hey everyone, thanks for all your help and I apologize for the long reply. I'm super embarrassed to say it but it turns out i was replacing and testing the wrong bulb the entire time. I kept mixing up the high beam/low beam and yeah.. bleh. all fixed
lnbear
Aug 3, 2013 10:06 PM
Critter
May 13, 2012 03:45 PM
flatmatt
Oct 25, 2009 10:22 AM
minib2200
Jan 26, 2007 06:59 PM
xtrigger
Aug 10, 2006 10:21 AM
