Pin assignments - Window master switch - 2010
Does anyone know where i can find the pin assignments for the plug that fits into the master window switch on a 2010 Mazda3 (or alternatively, the socket on the master window switch for the windows)?
edit: Though i think i found this here I am afraid i do not understand clearly how i am to proceed. My intentions were to jump power (1N?) to each of the windows open or close pins, but i frankly have no clue as to:
Thank-you, Merry Christmas & Happy New Year!
- how the interaction of the Ignition Pin (1M) interacts
- the function of the several pins labeled "Pulse(...)" (1D & 1H)
- Whether i need be concerned with the two types of grounds (1A & 1B)
- What Sensor Power Supply (1F) does
- And if i should be concerned with interaction from Door Open/Close Signal (1K)
Last edited by brucemc777; Dec 27, 2020 at 01:19 PM. Reason: Found probably diagram
punkascii
Aug 10, 2009 05:34 PM
