P0325
Old Feb 17, 2020 | 10:04 AM
AlRH1's Avatar
Exclamation P0325
Hello guys
I have check engine light for a P0325. I tested the knock sensor and cable are fine, On petrol and LPG but I still have the code even if I clear it, I have a Mazda 3. 2004 1,6 petrol 200kkm on the counter.
I don't know what should i check next ?
Old Feb 18, 2020 | 06:45 AM
How did you test the sensor?
Old Feb 18, 2020 | 08:18 AM
AlRH1's Avatar
I took the car to a mechanic he said he tasted it and its giving the correct voltage, Then he said it seems like its an ECU problem and he needs to reprogram it.
Old Feb 19, 2020 | 06:47 AM
You can't test the voltage of knock sensor, only the internal resistance. Only Mazda can reprogram the ECU, which will only be a software update, rather than a reprogram.
Old Feb 20, 2020 | 01:40 AM
AlRH1's Avatar
Thank you for the reply i am thinking maybe i should just replace it and see what will happen. i mean the car runs fine its fast its responsive, all symptoms of bad KS are not there,
a other mechanic said it might be because of LPG installation. that's why the car has a check light.
Old Feb 20, 2020 | 04:39 AM
You should of mentioned LPG in your first post. Do you know who installed the LPG?
Old Feb 22, 2020 | 12:54 PM
AlRH1's Avatar
no i don't know who installed it but it was done in Germany, thats all i know its a Voltran LPG kit,
Old Feb 23, 2020 | 01:20 AM
Get the code cleared, run it only on petrol for a few weeks and see how it goes. These engines weren't designed for LPG, not saying they can't be run on LPG.
Old Feb 23, 2020 | 11:32 AM
AlRH1's Avatar
Yes i tried that i cleaned the code and ran the car for 15days on petrol 95 unleaded premium and after like 2 days the code was back. I think your right Mazda engines are not so great for LPG however the car runs fine, on both LPG and petrol its just the code keeps getting back.
Ken Goach
Sep 3, 2019 07:14 AM
lqstqz
Oct 18, 2014 09:07 PM
my97626
Mar 15, 2007 03:20 PM
hottsy7
Oct 20, 2006 06:35 AM
