name of part/part number
Old Jun 25, 2018 | 10:09 PM
Urbs19's Avatar
Default name of part/part number
First post here. I have a 2009 Mazda3i 2.0 with 128,xxx miles. I have a coolant leak on the right side of the engine below the orange electrical connector. I have a coolant leak and i believe that its coming from between the block and the part i cant find a name for. I've asked different people for the proper name of it and got different answers. Car does NOT over heat. Its a moderate coolant leak. It is right below a frost/freeze plug if that helps. Any help would be greatly appreciated (other than being reminded that there is a screw missing.).
Old Jun 27, 2018 | 02:35 PM
RGAZ's Avatar
I can't see the leak but my vote is for the Coolant Temp Sensor based on your generic description. If its leaking from it, just remove it and re-install with teflon tape on the threads. If its leaking near it, then you might need to dig deeper in.
Good luck.
RGAZ
Old Jun 30, 2018 | 08:13 AM
Have a look at this link, might be part #17 &/or #18
https://www.onlinemazdaparts.com/a/M...S/5417120.html
Old Jun 30, 2018 | 08:14 AM
To properly confirm the exact location of the leak you need to pressure test the cooling system.
Old Jun 30, 2018 | 01:23 PM
Urbs19's Avatar
Thank you. Appreciate it
Urbs19
Jun 25, 2018 09:54 PM
TheChrisG
Apr 26, 2018 11:26 AM
317Highlander
Feb 2, 2018 03:04 AM
slightlee
Nov 16, 2017 01:50 PM
tcbmpv
May 19, 2013 12:12 PM
