Mazda3S Window Problem
Old Jan 4, 2013 | 01:06 PM
Danis's Avatar
Exclamation Mazda3S Window Problem
Hello everyone I'm new here. I have a 2005 Mazda 3S and I have a problem with left front window of my car, it doesn't go down at all, when I press the switch nothing happens and if I continue pressing the switch sounds a clic on the window but again nothing happens. The weirdest thing is that it happens mostly at the day when the weather is hot or very hot, because at night when the weather is cold the window works just fine? I don't know what to do, I think I'm going crazy with this?
Do you know what it could be ? I read something about a problem with a plastic or something like that on the windows mechanics that doesn't work on hot weathers? Is that true?
Thanks for your comments
Old Jan 6, 2013 | 06:25 AM
MazdaTirol's Avatar
It sounds like a thermal issue where something (contacts, connections e.t.c.) is expanding in the heat and not getting power, maybe a bad switch or a bad window motor? Only way I can think of testing it is to rip the door apart and put power directly to the motor, if it turns then its your switch, relay, wiring or the ECU for the windows, if not then the motor is probably bad.
jaimie08mazda3
Jan 5, 2009 10:13 PM
xamarshahx
Jan 23, 2008 01:36 PM
ShexyStephy
Dec 12, 2007 10:43 PM
germanshepherd
Jul 15, 2007 12:12 PM
RUFFSTUFF
Jan 16, 2006 04:08 AM
