mazda 3 oil loss
Hi,[/align]I have had a problem with my 04 mazda[/b] 3[/b] and was wondering if anyone has seen anything like this before. The other day I drove to work and evertyhing was fine. Somehow in the time that I was at work something happened with the oil[/b] filter or oil[/b] filter cup. When I started my engine all of the oil[/b] shot out of the engine. I had not noticed because of the way the parking lot is configured. I drove away and everything seemed fine. There were no strange noises smells or vibrations. Suddenly the oil[/b] light and engine light came on. I went to pull out of traffic and the engine seized up. The car has never leaked oil[/b] before. I checked the garage floor and found no signs of an oil[/b] leak. So all the oil[/b] leaked out in a matter ofseconds after I started my car. I have done some checking and have found that Mazda has a problem with their oil filter cartridge housing and can crack when tightened. I NEED HELP as I dont think I should be responsible for this repair because Mazda knows about this problem.[/align] |
RE: mazda 3 oil loss
Whomever did the last oil changewould bemore responsible than Mazda if over tightening the filterwas the problem.
RE: Mazda 3 oil loss
That would be my guess too.
You have to be pretty brutal on it, or use a metal strap style wrenchto get the oil filter housing to crack. It simply does not have to be tightened that much to do it"s job. I just hand tighten mine and it"s fine. Or perhaps they left the old O-ring on there. If so the oil pressure may have blown them both out because the cartridge did not seat as it should, but because of the extra friction the mechanic didn"t feel that and thought it had. I have seen this happen w/spin-on filters before. Back when I worked for Jeep, one of our "mechanics" wrecked a nearly brand new Renault engine that way. The customer only drove about 15 miles before the catastrophethough. We bought him a new engine. Whoops!! |
Well... I'm glad I don't use a Mazda filter for mine :D
ORIGINAL: knucklehead11 Well... I'm glad I don't use a Mazda filter for mine :D |
That's still a good argument for converting, but I would also be careful what spin-on filter I"d use. Some, like the Frams are said to be made cheaper than ever and collapse internally. If that happens...... do I hear a voided warranty?
Converting over is not a Green Modification according to both my local dealers
Neither is spilling oil, and potentially engine internals,all over the highway according to the EPA. ;)https://www.mazdaforum.com/image/s2.gif
I"m now completely out of warranty and I said before that when that happened, and/or I ran out of cartridge filters I would convert. I wonder if WIX makes a compatable spin-on filter? |
Here you go Richard
Part Number: 51215 UPC Number: 765809512153 Principal Application: Buell, Harley-Davidson Motorcycles, Ford, Mazda (03-09) (For chrome version, use 51225) [/b] All Applications Style: Spin-On Lube Filter Service: Lube Type: Full Flow Media: Paper Height: 3.404 Outer Diameter Top: 2.921 Outer Diameter Bottom: Closed Thread Size: 3/4-16 By-Pass Valve Setting-PSI: 8-11 Burst Pressure-PSI: 325 Max Flow Rate: 7-9 GPM Nominal Micron Rating: 24 Gasket Diameters Number O.D. I.D. Thk. Attached 2.734 2.430 0.226 |
WOW!!! GOOD info Ken. Thanks!
Where did you get/find that? Are you sure it"ll fit a 2.0... or a 2.3L converted? |
