Low Beam Issues
Old Apr 18, 2014 | 01:38 PM
natcon's Avatar
Default Low Beam Issues
Hello there,
I have read some treads here but no answers yet. I have a 2006 mazda 3 with 212,xxx on the engine.
I have no low beams. I have high beams, and dtrl. Fuses are good. wondering what people have found the fix was. Whether it be the light switch or having to replace the fuse panel under the glove box as it has built in relays for the headlights.
Old Apr 18, 2014 | 01:51 PM
Does your car have factory DRL's? Does it also have HID headlamps? If it does, are they factory installed or aftermarket?
Have you checked for voltage at one or both of the headlights?
With electrical problems you have to decide whether to start at the source, or what is supposed to be functioning and work either forward or backward from there. In the case of headlights, its usually easier to start at the bulb and/or socket.
Old Apr 19, 2014 | 04:27 AM
Do you have power & earth at the bulbs?
blue12
Nov 4, 2021 03:28 PM
twcinnh
Dec 9, 2010 09:48 AM
mazda guy
Apr 27, 2009 07:48 AM
dulcetcalamity
Oct 31, 2006 10:16 AM
mazdafan
Apr 29, 2006 02:35 PM
