help please
Old Jan 15, 2013 | 01:11 AM
Double check you have the right sensor, Some Mazda's have a "speed sensor" that is used for internal trans speed as well as another "speed sensor" that is actually a speedo sensor. Also I think your car actually uses the ABS/wheel speed sensors for the speedo.
Find someone with a diagnostic tool that has real time data logging that can display live vehicle speed while driving.
Old Jan 15, 2013 | 04:11 AM
racer662009's Avatar
There are 4 wheel speed sensors located on the spindal assy. Of each wheel. Generally if one of these goes bad u will get abs lights and traction control lights. U need a scanner or oscilloscope to check the output of the trans speed sensor as well as the wheel speed sensors. Rotunda makes gauge checker that u could buy and that will hook into the wires at the sensor to manually move the speedo to check the wiring and cluster.
Old Feb 10, 2013 | 07:24 PM
warlock360's Avatar
Default still not working
hello, i had check everything that all you guys had told me to do i even change the cluster and my speedometer still not working, anyone knows what else that i can do
Old Feb 11, 2013 | 03:21 AM
Start diagnosing the wiring.
ma929
Mar 8, 2020 03:44 PM
oderaro
Mar 10, 2009 10:25 AM
thomas1960
May 22, 2006 04:50 PM
temochen
Apr 17, 2005 12:28 AM
