Help. Charging system malfunction
Old Oct 31, 2022 | 12:14 PM
marlonpanizales's Avatar
Default Help. Charging system malfunction
Got alarms on my M3 3rd gen. Charging system malfunction. I already changed new battery and alternator but still i got those errors on my dash and infotainment screen. What should i do next?
Old Oct 31, 2022 | 12:38 PM
I would maybe consider to check if your ECU is at fault.
Why did you change the battery and alternator. Did you verify they were bad? Have you verified that the new alternator is function correctly? You may also want to double check your NEW battery as well by load testing it or having it load tested?
The Mazda ECU has the regulator built into it instead of the inside the Alternator, so it can more quickly take into account things like extra loads from fans which it is controlling.
slyg4m3r
Sep 23, 2021 11:22 AM
Merc
May 4, 2021 11:32 AM
NewGirlontheBlock
May 13, 2020 07:40 PM
sanimej
Jul 31, 2016 05:11 AM
PatIRWIN
Dec 19, 2010 11:13 PM
