Hankook Ventus V2 Concept Tires for 2006 Mazda 3 5-door/TPMS
Old Oct 25, 2011 | 10:59 AM
DevsAdvocate's Avatar
Default Hankook Ventus V2 Concept Tires for 2006 Mazda 3 5-door/TPMS
First post here, just had a question for you fellow Mazda owners.
http://www.amazon.com/Hankook-Ventus...9555729&sr=1-5
Tire Reviews - Discount Tire Direct
Found these listed while searching for new tires for my car. Anyone have any experience with them? Will they fit on my OEM 17" rims? My car lists size as: P205/50R17 88V
They look cool and cost isn't too bad. Free shipping from both Amazon Prime and Discount Tire Direct help make these work for me financially. I really like the winter performance reviews given my location in Northwestern New Jersey.
Thanks,
-DA
Old Oct 25, 2011 | 11:02 AM
shipo's Avatar
Thanks,
-DA
Right off the bat I'd say their load limit of 88V is a bit low; other than that they should fit your car perfectly well.
Old Oct 25, 2011 | 11:07 AM
Apologies. That's my vehicle's rating.
The actual tire rating of the Ventus V2 is: P205/50R17 93VR XL
Old Oct 25, 2011 | 11:16 AM
shipo's Avatar
That should work perfectly well.
FWIW, I just put a set of 205/50 R17 Yokohama AVID ENVigors on my Mazda3 and cannot believe how quiet the car is to drive now. The Yokos replaced a set of Michelin Pilot Sport A/Ss (which were about as noisy as the OEM Goodyear Eagle RSAs) which lasted 48,000 miles. If you're not wedded to the Hankooks, I cannot recommend the Yokohamas enough.
Old Oct 25, 2011 | 11:23 AM
I read good reviews about ENVigors, but I am looking for a lower cost solution. From what I read, these new Hankooks appear to be a great deal... the big plus being the winter performance.
Is Hankook a good tire brand in general? This is my first time buying them.
Old Oct 25, 2011 | 01:16 PM
shipo's Avatar
While I've never run Hankooks, I've heard generally decent things about them.
As for the tires you're looking at being a lower cost solution, the $19 (they're $118 over at TireRack.com) per tire difference between them and the Yokohamas may or may not prove to be lower cost in the long run. I say that because while the Hankooks have a treadwear rating of 500, the Yokohamas has a rating of 560; all else being equal (which it rarely is), the Hankooks should work out to be about ten percent less expensive for any given number of miles by the time they're needing to be replaced. Said another way, the Yokohamas should last about 12% longer than the Hankooks, and that extra tread life will at least partially offset their extra cost.
aguterez
Apr 16, 2008 01:04 PM
MazdaEric
Feb 22, 2008 05:19 PM
MazdaEric
Jan 28, 2008 12:46 PM
janz
Dec 6, 2006 11:35 AM
Caprice
Apr 12, 2006 08:24 PM
