fueling issues
Old Nov 23, 2005 | 04:54 PM
wendria's Avatar
Default fueling issues
i have an '04 mazda3 and every time the fuel tank gets to 1/4 when i add gas i can't start my car unless i push the gas pedal. it happened once when i fueled the tank full, too. i'm thinking it's the fuel filter but i'm not sure. any suggestions??? thanks.
Old Nov 23, 2005 | 07:12 PM
babyhuey's Avatar
Default RE: fueling issues
The no start only happens after you have added fuel to the tank? Ran across a similar problem last spring that turned out to be a evap canister purge solenoid valve stuck open. Should also be causing check engine light to be coming on with evap leak codes or fuel trim limits reached. Have had a few problems with fuel pump check valve allowing fuel to drain back into tank from injectors but that would just create a long crank time before starting and would usually have to sit for at least an hour or so.
jack17
May 5, 2015 12:26 AM
rickcoog
Apr 30, 2014 09:12 AM
