Filter Replace
It seems like it's a bit of a PITA to put on a CAI. Do you have to go through all that trouble to replace the filter or does a CAI make it easy to get to the filter?
Also, has anyone seen a difference just by putting in a K&N stock replacement or another brand (no CAI)? |
RE: Filter Replace
First answer: It"s not really that bad. About an hour- hour and a half. I removed the front bumper cover to do some additional exploratory surgery so it did take me some additional time. I wasn"t in a big hurry when I installed mine.
Second answer: Yes, and no. You can reach the filter through the now open sub-frame rail, but to actually get it off like that...? You should be able to approach it from the bottom though by removing or loosening the front splash shield apron. Third: No. I put a K&N panel in and noticed no difference. I cut additional breather holes and a huge slot in the bottom of the box (a poor man"s SRI.) No real difference either, imo. Some seem to like it, but I thought I had wasted my time... though it was worth the try at least. Anyone need a slightly used K&N panel filter?:D j/k ;) |
RE: Filter Replace
Ah, thanks for the info. With the filter before the TB and sensors, I wouldn't want to put an oily K&N panel in. I was thinking one of the new performance dry panels might be ok but, if the only difference is in your wallet, then I'll skip on that.
Say... why aren't there any computer programmers for these cars? Or are there and I just haven't seen them? |
RE: Filter Replace
Oh, can you put a cone filter directly to the TB? Eliminating all that plumbing?
RE: Filter Replace
ORIGINAL: Aubrey Oh, can you put a cone filter directly to the TB? Eliminating all that plumbing? |
RE: Filter Replace
SRI?
RE: Filter Replace
Short Ram Intake. An aftermarket intake, an alternative to a CAI that usually offers better top-end performance but a loss in low-mid range torque.
RE: Filter Replace
Thank you Richard. I wasn't around the computer to answer his question.
RE: Filter Replace
Ah, thanks. Hmm, I like my low/ mid torque. Dang.
RE: Filter Replace
My SRI really doesn't take away my low/mid range torque. I actually see better all throughout the power band with my particular SRI.
| All times are GMT -5. The time now is 12:49 AM. |
