Coolant & Fluids for Mazda 3 / CX-5
Old Jul 3, 2022 | 05:11 PM
mmitsch's Avatar
Default Coolant & Fluids for Mazda 3 / CX-5
Does anyone know if FL-22 is the correct coolant for a 2012 Mazda 3 sedan and for a 2014 CX-5 AWD? Also wondering what the correct Mazda P/N is.
I found this at Amazon and this doesn’t look correct:
Genuine Mazda Fluid (0000-77-507E-03) Gold Premium Coola... https://a.co/d/bPsQWNO
Also trying to figure out the automatic transmission fluid and brake fluid for both. Figured I’d keep them maintained.
Old Jul 9, 2022 | 08:07 AM
Same coolant for both vehicles, (10yrs / 120,000 miles lifespan ) Mazda FL22 Coolant 5 Litre K018-W0-122L5 Long Life Green Coolant
ATF for 2012 is Castrol Transmaxx Multivehicle. 2014 is genuine Mazda ATF-FZ
Dot3 or Dot4 brake fluid for both.
Old Jul 10, 2022 | 09:19 AM
mmitsch's Avatar
Is that coolant p/n from Australia? I tried to look it up and am guided to Australian sites. I have gotten feedback that 0000-77-508E-20 is the right stuff? Could you also let me know how much is needed for the 2012 3 and 2014 CX-5?
Thank you for the information on the ATF. How much is needed for those?
Appreciate your help!!!
Old Jul 11, 2022 | 05:23 AM
FL22 was Australian.
0000-77-508E-20 looks like the right stuff.
Workshop manuals says to fully flush the entire cooling system with water, drain it out, then top up with FL22, so 1 gallon would be right per vehicle.
Depending on weather you plan to drain & refill or flush the transmission will determine how much ATF you need. Drain & refill would need about a gallon per trans.
Steve Parker
Apr 22, 2021 09:13 AM
CharlieXray
Jun 12, 2018 06:59 AM
mazda567
May 10, 2013 09:54 AM
