Car won't run after Master Cylinder replacement
Old Aug 31, 2019 | 02:35 PM
BZM's Avatar
BZM
Angry Car won't run after Master Cylinder replacement
Help!! I had to changed the brake master cylinder. Once installed I put everything back together the same way as I removed it, then I bled the brakes. It started up right away and took it for a test drive went about 3 miles then got the ABS flash, then power steering goes out, then it gets stuck in 3 gear, then engine sputters and dies, cannot move the gear shift and when trying to run trouble codes cannot communicate with the engine computer. I went make and made sure all the connections where pushed tight.
Its a Mazda 3 Year: 2008
Engine: 2.0
Transmission: Auto
VIN: JM1BK32F081180589
ljenish
Oct 1, 2019 04:46 PM
spraga
Jun 25, 2018 04:41 AM
Hellohibonjour
Jun 16, 2014 12:14 PM
kallgrer
Jun 6, 2007 09:14 PM
grytrib
Jun 5, 2007 01:50 AM
