a/c blowing warm air
Old May 24, 2011 | 10:44 PM
RyKerZ's Avatar
Default a/c blowing warm air
So as some of you know, I was involved in a $2,000+ fender bender recently. Since then, my air conditioning hasn't been able to blow cold air. I took it into a garage for a preliminary inspection - and they said the clutch/compressor isn't working or engaging when they turn the ac on/off. They said I would need a new compressor, which runs ~$6-700. With labor it would be around $1000. This is the only place nearby that deals with auto a/c and I was wondering if there are any cheaper alternatives? Has anyone else run into this problem?
Old May 25, 2011 | 11:30 AM
Tracker's Avatar
well first off id ask them to do a test to see if you have a leak, if you dont have enough refrigerant your compressor will not turn on. If they find that there is no leak and the compressor will still wont turn on then you either have an electrical issue or its bad. The price that they gave is accurate for parts and labor and actually the cheapest ive seen so far, id just make sure they know 100% that the compressor is bad. the only cheaper alt is finding a junked 3 and replacing the compressor yourself then have a shop recharge your system.
Old May 26, 2011 | 06:25 PM
RyKerZ's Avatar
They didn't test for a leak the typical way (by putting dye in the lines and having me drive around for a couple weeks); instead they pressed some sort of valve under the hood that indicated that the lines were pressurized or something? Meaning there wasn't a leak? I don't know if that has anything to do with a potential leak, I didn't really follow.
Old May 28, 2011 | 10:39 AM
Tracker's Avatar
the only thing i can think of other than a bad compressor is the ground for the compressor is ripped torn or something electrical, which would involve a schematic diagrams and tracing small wires, ripping apart your harness....yeah you get the pic. your better off having them deal with it and if something goes wrong of it dont work, then you bring it back and have it fixed/looked @ for free.
Old May 31, 2011 | 12:18 AM
SPEED3EATSV8's Avatar
cabin air filter was replaced when? clogged, dirty filter means little to no cold air....
Old Jun 1, 2011 | 04:03 PM
RyKerZ's Avatar
yeah I'll probably just have them replace the compressor and see if that fixes it.
I haven't replaced any filters in the car since last year (~365 days ago), could the cabin air filter really be the cause of warm air?
Old Jun 3, 2011 | 11:06 AM
Tracker's Avatar
warm air? no, reduce amount blowing though, yes
Old Jun 5, 2011 | 11:19 AM
Hmmm, clogged cabin air filter has a profound effect on the a/c system's ability to make and blow cold air efficiently.......Try not changing your furnace filter or a/c filters at home and see how THAT affects those systems ability to perform......
Old Jun 5, 2011 | 12:48 PM
Tracker's Avatar
a clogged air filter is not gonna make it blow warm air, its going to reduce the amount of cool air coming through it. i ve experienced it in my friends 6, i wouldnt know from my car because it didnt come with one.
Old Jun 5, 2011 | 01:25 PM
YOU are incorrect........ask a factory certified master technician......
Put a clogged filter in a window air conditioner - see how cold the air is you get out of it....
