Air duct for battery
Well, I talked to the local Mazda service technician and he said that it would not harm anything to remove the air duct. He said it was actually a good idea to remove the air duct if I were to install a cold air intake or short ram intake. Although, he did saythe air ductwould keep the battery a little cooler which prolongs the life a little.The technicianalso said that 90% of today's carsdon't haveair cooling ducts.In conclusion, I have decided to remove the airduct but I'm going to keep the battery cover intact.
Let me get this straight, you're going to remove the air ductthat provides colder air to the battery for longer life, and leave the cover on so the hot air that does get in and surrounds the engine will overheat your battery?
Did you think this through?
Why is it so necessary for you to remove the air duct in the first place?
If it's convenience, just remove that stupid little triangular piece of plastic that supposedly hold it in and grind off the tabs on the air duct itself... like this:
ORIGINAL: virgin1
Now, I'm kind of confused why you cut off the side mount from your battery cover when I can see that you still have the stock air intake box intact. What was the reasoning for this besides maybe getting some of that plastic out of there?
ORIGINAL: Drift3s
... Now, I'm kind of confused why you cut off the side mount from your battery cover (duct) when I can see that you still have the stock air intake box intact. What was the reasoning for this besides maybe getting some of that plastic out of there?
I am no longer running the stock box. I am running an MS CAI. This is an older picture that I had for the purposes of a write-up I did. Hence the circles and arrows.
virgin, where did you get the K&N battery duct, or it's just a sticker?
________
The Legend Condominium Cosy Beach
________
GopherInWI
Oct 11, 2025 08:51 AM
carilliterate
Apr 19, 2014 05:17 PM
Gateway Lady
Nov 26, 2012 11:18 AM
