2010 iT works, and then doesn't? Frustrating.
Old May 18, 2017 | 11:00 PM
cutiebud's Avatar
Default 2010 iT works, and then doesn't? Frustrating.
I have a 2010 Mazda3 i Touring Sedan with 79,000 miles on it, and during the snowstorm, the shield under my car broke off partially, and I had to get it removed.
I had my serpentine belt replaced, but then had to send it back in for the A/C and got that fixed. Now these lights are all on, and the car seems like the transmission is slipping.
However, sometimes the lights go off, and the car is fine for a day or so. Mechanic said everything was fine when it was returned, but this happened a day later.
Last edited by cutiebud; May 20, 2017 at 03:53 PM. Reason: Remove useless information
Old May 21, 2017 | 04:42 AM
You will need to get a diagnostic code check done.
I'm guessing a issue with the ABS/DSC system. It could be a damaged ABS sensor/wiring on the RHF.
Early 2nd gen Mazda's 3's are also known for dodgy DSC HU/CM ( Basically the ABS pump)
Old May 23, 2017 | 12:57 PM
cutiebud's Avatar
Thumbs up
Thank you so much. I work from home and driving the car scares me when it's skipping around (it feels like it doesn't want to go into 2nd gear now) but I will get to autozone here to check the codes immediately.
ttommy
Dec 8, 2013 09:08 AM
Almaz
Sep 3, 2012 01:51 AM
TANK1
May 22, 2011 03:47 PM
pkeddie
Jul 9, 2006 11:04 PM
