2010 Mazda 3 door locks
I have an aftermarket remote start that works correctly. The issue is the door locks don't work at all from the door switch or the fobs. When I depress either of the switches all I hear is a click from behind the fuse panel located just inside the drivers doors. Is there a central fuse or relay that's failed?
It's not that bad having manual locks, you'll just have to get used to using the key to unlock and reminding passengers to lock the door on the way out then double checking to see if it's locked. It's really no big deal, I wouldn't mess with trying to install power locks.
Kodi nox
Kodi nox
korgman
Feb 23, 2011 03:29 PM
jesska
May 12, 2006 01:09 AM
