2009 defect
hey guys
i have an 09 mazda 3 touring
i was wondering if any of you came across this problem.
Whenever i use the turn signal, i seem to inadverdantly activate the highbeam light. And it happens very often. Has anyone else come across this freak occurance and have you been able to do anything to correct it.
Thanks
Luis
Thanks
Luis
Not really a defect, just 1 bad thing about having a Multi-function switch, and it has happened to me, and on more than 1 vehicle also.
I have just learned to put up or down pressure on the stalk and it does not happen all that much.
I concur with Siber Express, it isn't really a defect as much as it is poor ergonomics. I'm thinking that if the turn signal stalk was a half of an inch or so closer to the plane that the steering wheel turns in, the occasional activation of the high-beams wouldn't happen any where near so often. FWIW, I've owned a number of German cars with the same push away to activate the brights, pull toward to "flash" the brights, and I've never inadvertently turned them on before I bought the Mazda.
I prefer the relay activated pull-on/pull-off high beam stalk as most of my old Volvo's, Opel and Honda had, but this is what we have now in the Mazda and most cars I know of.
I too have occasionally flipped the highs on when using the turn signal, but not very often. (+/-3 times in 4+yrs) A little practice and attention to detail and it'll become second nature to you too.
Meh. It's happened to me a few times. There isn't very much resistance against the force of pushing it away. My Mustang's brights and bright flashing worked the same exact way, but I never accidentally turned on the brights in this fashion. Then again, there was more resistance, thus less chance of accidentally pushing it back. On the Mazda it barely takes any strength to move it.
