2007 Mazda 3 alternator overcharging
Old May 19, 2020 | 05:26 PM
mxtech's Avatar
Default 2007 Mazda 3 alternator overcharging
Got a check eng, traction control,and battery light on. I checked the battery and was getting 20.4v! I changed the alt and it’s the same thing. Advice anyone?
Old May 19, 2020 | 09:11 PM
Ricardowelch's Avatar
Originally Posted by mxtech
Got a check eng, traction control,and battery light on. I checked the battery and was getting 20.4v! I changed the alt and it’s the same thing. when you should replace car battery, visit AutoGuysLand to get more info. Advice anyone?
It could be issue with the related components with alternator as bad regulator or bad maf. Try to take a look at this too.
Old May 23, 2020 | 08:25 AM
Be aware the alternator is controlled by the PCM.
Get the alternator professionally tested.
I've had to replace PCM's before due to charging issues.
Old May 23, 2020 | 03:30 PM
mxtech's Avatar
Thanks for the reply, I haven’t been able to get a definitive answer on that. I can see there is a voltage regulator in the alternator but I have also read it is controlled by the pcm. I can get one for about $200 US but then I have to pay to get my keys reprogrammed also I believe. I don’t mind doing it if it works. I don’t think it’s the alternator, it would be too much of a coincidence that they both put out 20.4v!
BengalBrad
Apr 1, 2015 08:20 PM
Jprotege
Dec 10, 2011 08:15 AM
Loungerist
Jun 13, 2011 02:48 PM
kcjaeger
Mar 12, 2007 11:42 PM
gdefig
Feb 3, 2007 09:36 AM
