Wrench Light Flashing
Old Mar 14, 2022 | 06:45 AM
KRZ's Avatar
KRZ
Default Wrench Light Flashing
Hi All,
I have a 2015 Mazda Demio/2 Skyactiv-D 1.5 that was imported from Japan to New Zealand. For some reason the Wrench/Maintainance light keeps flashing. So far we have changed the Oil and reset the oil data and also disconnected the battery for 20 minutes however the Wrench Light keeps flashing.
I have read on another forum that it may be due to a maintenance alert where you are required to either drain or replace the Fuel Filter however the error needs to be cleared by an authorised Mazda Dealer? Would that be the case or if I went and changed the fuel filter would the wrench light stop flashing.
Keen to hear your experience/thoughts
Cheers
KRZ
Old Mar 14, 2022 | 08:20 AM
M Two's Avatar
Originally Posted by KRZ
Hi All,
Cheers
KRZ
Old Mar 14, 2022 | 02:15 PM
KRZ's Avatar
KRZ
Hi,
Thanks, we have already tried that unfortunately that did not solve the issue.
Cheers
KRZ
Old Mar 15, 2022 | 06:25 AM
You need a scan tool to reset the oil data.
Have you scanned it for fault codes?
Flashing on a diesel usually indicated DPF issues.
Old Mar 15, 2022 | 06:30 AM
KRZ's Avatar
KRZ
Thanks - No scan yet. The DPF light hasnt gone off yet. I will be looking to take it into the Mazda service centre this weekend.
Old Mar 15, 2022 | 10:28 AM
Mazdaon's Avatar
Try this:
1) Car off, press start button once
2) Press and hold start button and trip meter(without starting the car) for several seconds, an orange triangle should start flashing, when triangle stops flashing let go
I just re-read post and realized you have a Diesel, in this case it's a Fuel sedimentor alarm and comes in every 20K or 30K kms, yep you need to visit dealer, drain fuel separator and reset data.
Old Mar 20, 2022 | 07:40 AM
Has it been scanned for fault codes?
Old Oct 27, 2022 | 07:16 PM
Daniel_Davinson's Avatar
Hi All,
Cheers
KRZ
Hi, do you solved it? I got the same wrench light flashing in my Mazda Demio 2018 and I can't fix it .
Old Sep 24, 2024 | 07:21 PM
rachiedaily's Avatar
Default Did you figure it out?
Greetings, I would like to know if you solve this issue?
SJD712
Mar 2, 2018 04:23 AM
donofwon
Nov 11, 2013 03:45 AM
rexdog
Mar 27, 2011 01:44 PM
Kazel
Oct 31, 2008 04:36 AM
Eric
Mar 28, 2006 03:18 PM
