Torque Curve for each gear
Does anyone has the Torque Curves for each gear?
-->Mazda 2 (1.3 L 84hp 2009) I have found this: https://www.automobile-catalog.com/c...ependence.html But I want something more detailed. Thanks |
Originally Posted by nikolas126
(Post 197328)
I'm not an expert on these things, but I'm not sure how the torque curve depends on what gear you're in; it's just a characteristic of the engine. Isn't it?
Originally Posted by matth1j
(Post 213718)
It is not normally not really important unless you are either Drag racing or long track Road racing. And if it is for anything else can't say as I can see what you would need it for ? Besides the reason I deleted my first response is because I didn't notice how old the thread was and the extent of the OP use of this forum after this thread. So basically we are likely never going to know what he wanted it for? LOL OH and it you noticed he was BANNED from this forum for attempting to remove historical content without permission from the moderator and or Administrator . ;) |
I guess you might look at one to get some idea of how 'easy' it's going to be to drive. For example you'd expect the graph from a turbo engine (and diesels even more so) to climb to a peak relatively early, meaning you don't have to rev its nuts off to get the best out of it. Unlike us Mazda owners with normally aspirated engines, where the torque comes in higher up the rev range.
(Post 213721)
Sorry, don't quite follow. Just saying that compare the torque curve of the average turbo petrol with a non-turbo petrol and the former will peak sooner and probably be flatter. That's what turbos do :)
(Post 213723)
Most of those Dyno are not empirical data to use as a guide for your type of comparison. Lok at your DYNO result when you got your personal Mazda tested how would you compare that to other Mazda's that were independently tested by owners? First are there same Dyno's used and what about the Dyno setting prior the test. Are they the same as yours. Then the engines condition? So many things to compare before you can make a statement like your first in this thread! |
