Problem with Odometer display
Old Nov 14, 2025 | 08:51 AM
SeaJayDee_NTFC's Avatar
Default Problem with Odometer display
Is there any body who can please advise on if this is an easy fix
I’m wondering please if anyone has any advice on how I can fix this? The odometer has just stopped displaying, I’m guessing it’s going to be an electrical issue, but not sure of where to start!
any advice would be greatly appreciated 🙏🏻
Old Nov 14, 2025 | 08:57 AM
Year , exact model, and last odometer readings
This “may” be BCM related ?
Old Nov 14, 2025 | 08:58 AM
Old Nov 14, 2025 | 09:03 AM
It’s a 2016 Mazda 2, it usually displays fuel gauge and mileage left…. And thank you!
Old Nov 14, 2025 | 10:38 AM
I did look and there is/was (VIN dependent) an ECU update. This was available free when the warranty was still active so getting it now through an independent service shop or a dealer will cost. There is ways to check for the health of the BCM but don't take offence unless you or the person checking is Diagnostically trained it is unlikely the service will or can be done correctly and it requires professional grade Automotive diagnostic equipment.
The DIY(do it yourself) (not in any way a service a shop would do) is to discount the cables from the battery negative side first and then positive side. Then disconnect the BCM. Reconnect the battery with the positive side first and then the negative side. Then start the engine run for several seconds then turn off. Then repeat the battery disconnect and connect procedure and when the battery is disconnected re-connect the BCM. Then after you reconnect, the battery restart the engine? Cross your figures.
I repeat this is a DIY attempt only to reestablish the BCM reporting. If the odometer does not re appear then the Mazda should be taken to a Mazda dealership or a service shop that has a certified Diagnostic Technician employed. No average mechanic or claiming Diagnostic skills or a shop that has a Mazda Factory Trained Mechanic.
DISSCLAIMER:
This service steps provided is from one member to another (we will state for this thread and response one DIY to another DIY) and not a service that is in any service manual. This is also NOT a proper service procedure that any service shop would do. But a DIY often can attempt to try things outside the correct service steps in hopes of solving or resolving issues.
The DIY will NOT harm the BCM or ECU if done in the safe steps
ZoomZoomGal
Jul 10, 2024 09:23 PM
MazdaMadison15
Jul 4, 2022 01:31 AM
ZoomZoomGal
Aug 23, 2019 11:24 AM
OldFart
Dec 20, 2017 11:42 AM
mazda guy
Nov 19, 2007 09:21 PM
