Power windows not working
I have had a 2006 Mazda 2 since new.
Recently I had to replace the battery and since then , the only power window that works is the drivers one.
None of the other 3 windows work, either from the drivers settings or their own settingsI checked the Mazda manual about re-setting the windows but that didn't work as the windows don't go down.
I tried holding down each switch and slamming the doors a few times but no luck.
I have sprayed silicon all around the trims and the switches, no luck.
Disconnected the battery again, no luck.
Surely all 3 motors have stopped working at once and the switches as well
I have checked about the window fuses and there is only 1 fuse that operates all windows.
When you press down on the drivers passenger window switch, you can hear a clicking noise but not on the rear windows
