Overheating issue
Old Jul 15, 2019 | 12:35 PM
Flash2204's Avatar
Default Overheating issue
My 1.3 2008 Mazda 2 has been over heating. It did the first time on a the way back from a weekend break. It was fine going there, but on the way back it started to over heat after about 40 miles.
Ive had the thermostat changed the engine coolant sensor changed. Fresh coolant, cleaned the bugs out of the radiator and pressure tested and it was fine? Blocked radiator? The cooling fan kicks in around 100°c
If I turn on the heater on in the car it cools down
Old Jul 16, 2019 | 04:16 AM
Samlcampbell's Avatar
. Does the heater stop the overheating or is the heater starting to blow cold? If second option then could be water pump.
Old Jul 16, 2019 | 09:18 AM
Flash2204's Avatar
Yes the overheating stops as soon as I put the heater on in the car. It blow hot air out
Old Jul 16, 2019 | 10:54 AM
So its less likely to be the pump. Another thread suggested a mazda dealer to check ecu , thik te said they could do a diagnostic cheeck
Tammy Saunders StClair
Apr 9, 2013 06:01 AM
my2monkeys
Nov 20, 2012 09:58 AM
kyleagrant
Apr 29, 2009 12:05 PM
danattamco
Apr 26, 2006 04:09 AM
muddytazz
Jun 19, 2005 02:55 AM
