Occasional jerking/hesitation when accelerating from 2nd gear
Old Mar 25, 2024 | 02:29 PM
benjibar's Avatar
Default Occasional jerking/hesitation when accelerating from 2nd gear
Good day all.
i have an issue with my 2020 Mazda 2 dynamic auto.
my car occasionally jerks when i accelerate from 2nd gear and at low rpm. The issue happens when i am accelerating from from 1st gear into 2nd gear between 1800 - 3500 rpm. There is a sharp thud when the car downshifts into first gear.
all the above happens occasionally.
i took the car to Mazda and they inspected the tcm, the fuel level and they confirmed its 100%. They did a software update but the issue is still there.
i took the vehicle to have the suspension inspected and the engine mounts inspected as well, everything is 100%.
i am wondering what more could be another possible culprit for this or if someone out there has experienced something similar and can share?
at this point i am thinking maybe it is a bad torque converter?
Old Mar 26, 2024 | 10:49 AM
The miles helps to know when asking problems.
If you have over 100k miles when was the transmission service last and at what miles? You are describing a transmission that the valve body and servos are sticking due to long period of not doing basic transmission service. i.e. pan filter and fluid changes. If you do not at least have you pan dropped and inspect the condition of the visual parts as well what has settled in the pan you could be looking at a transmission failing in the near future.
Naturally you also need to check the ECU/TCM for history of pending DTC that could be related to your problems. (I am suspicious something was overlooked when you had it checked)
Old Mar 26, 2024 | 03:26 PM
benjibar's Avatar
Default More information
here is more information
my 2020 mazda 2 dynamic auto has 67480km on the clock (with full service history)
I took the car to Mazda and they checked the transmission fuel quality and level and deemed it 100%. They suspected either the engine mount or the suspension, but Car service city (a service centre here in South Africa) ruled those out and deemed them 100%. I have just done a major service(oil filter, engine oil, spark plugs) on the car but the issue is still there.
i have no idea if the car has had a gearbox service done to it, i bought the vehicle second hand.
Old Mar 26, 2024 | 04:52 PM
Not sure how they based on the information you told me anyone could have concluded it was a supporting mount??? If you had a failed or failing mount, you would feel it in all gear changes not just a couple. And not sure what they or you meant by suspension because again your explanation of the problem you would notice in more than just one or 2 gear changes.
Unless they took a sample of your transmission fluid and sent it off to be analyzed they and no one can state the condition of the fluid. Unless the transmission pan was removed and inspected what has settled and also look at the valve body no one can state the true overall health of the transmission.
I have no cluse who the places you have been taking your Mazda to get service work I have not yet had the pleasure to visit your country, but I know one thing ... I am not impressed with the automotive service shops there?
CarloC
Oct 23, 2023 03:56 AM
Hemp6473
Apr 22, 2021 04:14 PM
mpc12347
Aug 22, 2008 07:56 PM
damir233
Apr 7, 2006 12:49 PM
Zoom Zoom
Oct 1, 2005 01:08 PM
