Mazda2 DE 1.5L MZR ZY-VE Engine - Heater Hose Connector Leak
Old Feb 13, 2026 | 09:59 PM
OZCorolla_x2's Avatar
Smile Mazda2 DE 1.5L MZR ZY-VE Engine - Heater Hose Connector Leak
The MAZDA2's run hot & for a 2009 "plastic & hoses" are geting old.
D6516124YB Connector & Hose
D6516124X Connector & Hose
D65161240 Connector Only
Anyone else had a Coolant Leak from the Heater Hose Connectors?...the leak for mine has developed over the last 600km or so....
Fig: Heater Bottom Connector Leak
Fig: Heater Bottom Connector Leak Mark on top Connector also
So probably up for two new Connectors & Hoses
Rob
Old Feb 22, 2026 | 07:34 AM
Smile
Ordered parts on Monday they arrived Thursday
Fig: New Hoses Quick Connectors, Hose Clamps & Rad Cap
Had some time so replaced the Heater Hoses & Quick Connects
Remove the Battery, & ECM/Air Filter Cover, makes access easy for the Heater Hose replacement. You don't need to remove the standard air intake/plastic over the coil packs.
IMG_0556 Battery & Air Cleaner plus ECU Removed for Ease of Access to Heater Hoses LoRes2.webp
Fig: Battery & Air Cleaner plus ECU Removed for Ease of Access to Heater Hoses
About 1Hr all up then 10 min drive & check the heater hose connections, then a 1/2Hr Hway run & checked the heater hose connections for seepage
Checked the coolant level the following morning when car was cold & topped up coolant header tank. Also checked the Heater Hose connections & Radiator Drain Valve for seepage
IMG_0552 New Heater Hoses Position Hose Clamps for Ease of Access LoRes2.webp
Fig: New Heater Hoses Position Hose Clamps for Ease of Access
All good.
Rob
Saudade
Nov 24, 2024 04:18 PM
Police Robot Tokyo
Sep 7, 2022 07:42 AM
J. Ringo
Mar 8, 2021 09:14 AM
Joe850V12
Feb 18, 2021 10:59 PM
Mummamia
Jan 29, 2020 05:17 AM
